跳转到主内容
Microsoft Surface Pro 系列二合一平板电脑的维修指南和信息。
How do I identify my specific model of Surface Pro?
How do I identify my specific model of Surface Pro? I tried the System Information but it says only Surface Pro. Under System SKU it shows Surface_Pro_1796. I need to replace the battery and want to order the right one, the first time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Hello, if you put your serial number in this link -> Check Warranty Page - ROBO SelfServe Portal (surface.com)
It should come back with the exact model.
To find your serial number you can use this microsoft guide -> https://support.microsoft.com/en-us/help...
这个答案有帮助吗?
得分 6
1条评论:
Thanks for the response. I found the serial number in the Surface app on the device, it's a Surface Pro 5th Gen which I also found out is AKA Surface Pro 5. Thanks again for the quick response, now I know which battery to order.
完成的
添加一条评论
Thank you
The link works fine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keith Ball 将永远感激不已
浏览统计数据:
过去 24 小时: 55
过去 7 天: 372
过去 30 天: 1,480
总计 46,085
