跳转到主内容
蘋果2020年的主流 iPhone 機型,發布於10月23日,搭載6.1吋 OLED 螢幕及12MP 雙鏡頭模組,有著5種顏色。該機型為 iPhone 11的後繼產品。
Why is FaceID not working after screen replacement?
I replaced my cracked screen with a display from iFixit, and made sure to use the front camera part from the old phone and put it in the new display. However, the phone now says "unable to determine if display is genuine" and it disabled FaceID. I was under the assumption that if you used the original front camera part FaceID would still work. Thank you for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
@rs0087, If you used the phones original front cameras + flexes, just replacing the screen, then yes; The FaceID should work.
I’d start by opening it up again, then disconnecting battery (always battery first) followed by the screen assembly. Inspect all connectors and flexes under high magnification for damage. If there’s no sign of damage, reassemble the screen assembly making absolutely sure every connector is married up properly. Finally replugging the battery, but before gluing the phone up again, test it for functionality, ie the FaceID.
这个答案有帮助吗?
得分 2
添加一条评论
Is iOS up to date? This did affect iPhones but then Apple changed it in an iOS update.
这个答案有帮助吗?
得分 1
添加一条评论
Hello! Does it matter if it is not a genuine part? Do we have to reprogram Face ID and True Tone function with a dedicated programmer?
这个答案有帮助吗?
得分 1
添加一条评论
Even with Apple Original parts, it won't work. I just replaced my iPhone 12 screen with another iPhone 12's screen, not working anymore. In fact, I exchanged the motherboard (and screen's board) from a damaged iPhone to a new iPhone 12 (same model A2402). Everything is running smoothly except that I have loads of warnings in Settings, explaining that I haven't used Apple original hardware... Yeah right...⏎
So the catch is that Apple has some hidden settings to certify that the exchange was "official". It works, but no Face ID. The rest works perfectly, even with the warnings.⏎
You fix the screen, say adios to Face ID. And with the price of Apple repairs, better buy a new iPhone...
这个答案有帮助吗?
得分 0
1条评论:
This is subject to change in iOS 18, which is releasing tomorrow. With iOS 18, you will be allowed to pair OEM parts to phone.
完成的
添加一条评论
添加你的答案
Bob Winters 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 179
总计 9,028
