跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Why my monitor suddenly turning off when playing games?
My monitor suddenly turning off automatically (light turns to orange) when playing games. Never happens when browsing, office, discord, YouTube. I have to forcefully reboot the pc by pressing the power button.
One thing I tried to see what's happening is to connect my android via remote desktop. Through my android, sometimes I can still see the desktop, there's no error popping up and I can move the cursor through my android (mouse doesn't work). More often it was just black as well but can still see and move the cursor and hear the sounds as well.
I've been using this pc for about 2 years now and this problem started to occur 2 days ago.
Games I play are Dota2, Valorant, Genshin.
AMD Ryzen 5 3600
RTX 2060 Super
B450M Mortar Max MS-7B89
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello Kami, I just had a couple of ideas you might want to try. If I understand correct your monitor will enter sleep and then you have to reboot your PC, but you can see it from remote desktop. The first thing I would do would be to try a different port on your graphics card, different cable, different input on your monitor (if you have multiple), different monitor (if you have an extra). I would also maybe check for new drivers from Nvidia. However if your using DisplayPort, I would check the cable first; as the cable could be losing connection, which would explain why remote desktop can see it, and the reason you would have to reboot is because DisplayPort is not hotswap. I hope this helps you out, have a nice day!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kami Sama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 41
