跳转到主内容
Repair and support for the 2015 version of the Google-produced laptop line, the Chromebook Pixel. This newer version improves the processing power, battery life, and adds new features to the 2013 model.
Remove R/W screw to boot into Windows
I am looking to do a complete OS installation of Windows. I know the process of completing that through Mr. Chromebox installation guide. However, he mentions that you need to open the Chromebook and remove the R/W screw inside in order to fully flash an alternative OS such as Linux or Windows. Has anyone attempted this? If so, please describe where the screw is located? I know to open the Chromebook you just pry up the rubber pieces on the bottom. However I want to make sure I am only removing the correct screw on the inside.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I found a video on youtube showing EXACTLY what screw to remove. Wanted to share with the community. https://youtu.be/wOsezY7znZ8
If you need any help please feel free to reach out to me. I'll be giving this a try as well as performing the installation of Windows. Already have Dual Boot of Ubuntu/Chrome OS - due to no longer receiving updates I use Ubuntu ONLY at this point other than to run some terminal codes to install other flavors of Linus from ChromeOS.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rickluebke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 233
