跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Why is my MacBook Pro 2011 stuck on a white screen?
Hi!
My Macbook Pro 2011 is just stuck on a white screen and resetting the PRAM etc. did not work. When I turn on the computer, it shows a white screen and I hear the chime. But there is no apple logo on the screen. Just a plain white screen, no matter how long it stays on. What shloud I do? Thank you very much in advence.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Give this a try to check things. Restart your system and press the T key to enter into Target Disk Mode. At that point the screen should show either a FireWire or Thunderbolt icon. Did it? If it does this is telling us the discrete GPU has failed and it can’t get past the startup POST process.
We can trick the system once you can get past POST. Here we can force the system to use only the integrated graphics engine within the CPU. But it’s not as good as the discrete GPU.
Sadly, this series suffered from a few different issues which are working against you. Frankly, I think the smarter solution is swapping out the logic board to a much better one! I can tell you I’ve done quite a few and my own 2011 is likewise running with a 2012 logic board. Review this guide MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement basically it’s a clean swap out with one minor alteration to the display cable as Apple changed suppliers so yo need to use a common nail file to grind down the fiberglass tang ever so slightly equally from each side at the width is a bit narrower with the socket.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 16
