跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
282 个问题 查看全部
Speakers stopped working after battery replacement
I’ve had a swollen battery on my MacBook, luckily everything -apart from the battery was working- but after the battery was changed, the speakers don’t seem to be working, and when I press the sound buttons on the keyboard, I get the icon attached.
What might be wrong and how can I find out what’s wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Review this guide Retina MacBook 2015 Audio Jack Board Replacement either the cable leading to the board is not plugged in fully or may have become damaged or the board has failed.
这个答案有帮助吗?
得分 1
6条评论:
Does the Audio Jack Board have anything to do with the speakers?
完成的
@genik - Yep! If you look at the board you will see a large square chip with CIRRIUS printed on it. This is the DAC chip which converts the digital signal to an analog to drive the speakers and the audio jack for your headphones.
Apple loves to maximize the internal space usage squeezing so much in a small space.
完成的
@danj other than the three possible issues you suggest might there be anything else i should have a look at?
(btw you say "the cable leading to the board..." is that the "audio jack board ribbon cable" you are referring to?)
完成的
@genik - just the cable.
完成的
I have the impression that when changing the battery, the Audio Jack Board Ribbon Cable is totally untouched, simply because the battery replacement occurs in the underneath case... I could be wrong though :-)
完成的
显示更多的1条评论
添加一条评论
添加你的答案
genik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 362
