跳转到主内容
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
75 个问题 查看全部
Moved screen, it si a bit offset
Hello guys,
a few days ago, I accidentally dropped my mac. And somehow the mac's screen moved a little and it's offset. Is there any way to fix it? Like just by unscrewing the screws and moving the screen back?
But everything else looks and works just fine.
As you can see in the pictures, one side is moved back, the other is where it's supposed to be.
It's also moved a bit on the sides.
Thanks for help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
While there is a little play in the displays mounting it’s hard to tell with the limited images if that would be enough to correct this. Review this guide MacBook Pro 14" 2021 Screen Replacement basically you will need to follow it for the first part to disconnect the battery getting through to Step 16. Then jumping down to Step 32 to loosen the hinge screws so you can shift the display.
Do inspect the cables as they can get damaged from the shift.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ondrej.hobza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 133
