跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
459 个问题 查看全部
Upper screen ribbon has a small gap. Can it be bridged with solder?
Hi,
While inspecting the 3DS with a broken image on upper display (discolored, image appears zoomed in 2x so only left side is visible), I noticed that when I pulled out the ribbon out of the socket that one of the pads is separated. Just under the 15th pad, the line splits and there's a visible gap. I could attempt to solder to it, but I'm unsure if it's possible. Is there a temperature these ribbons can survive that's suitable for soldering, or is it not possible?
I checked with the multimeter and the pad and line are not connected.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I don't remember trying to solder on one. I would find a piece of bare flex and heat it to determine the consequences.
Due to size, it will be difficult and you don't want solder on the lower portion of that contact.
这个答案有帮助吗?
得分 2
1条评论:
Good idea. I'll try to touch the empty area of another water damaged 3DS to see what would happen.
Maybe I could isolate that gap with carefully positioned pieces of kapton tape?
完成的
添加一条评论
添加你的答案
StereoBucket 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 29
