跳转到主内容
一款任天堂为 Switch 系统生产的无线、经典的视频游戏手柄。型号:HAC-013。
How to remove a stripped screw from Pro Controller?
I'm trying to replace the shell of my Switch Pro Controller and one of the screws got stripped. I've tried the rubber band method and the superglue method, but neither worked, and now there's glue caked in there. What would be the best way to remove it? I'm leaning towards trying to remove the glue with acetone and then using either a screw extractor or drill bit, but I'm unsure about the best course of action or the best products. I don't care much about the plastic of the handle getting damaged, as that's getting replaced anyways.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @mhill6229 ,
I would use a drill bit with the same diameter as the screw head to drill the head off the screw.
Once the head is gone, you should be able to lift up the handle over the screw's threaded shank and once it is exposed use pliers to unscrew it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ken H 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 612
