跳转到主内容
加入维修社区 - 创建账户
Phone won't always display, but works fine when it does
Hi,
I recently cracked my S10lite very lightly on the right hand side. When I press the lock button to wake up the display it doesn't always work (takes about 6 or 7 tries to then display the lock screen succesfully). However, when the phone successfully displays there is no problem - the touch screen still works even under the crack itself.
Would looking to replace the just the glass fix the issue? It seems that there is no problem with the digitizer if the touch screen works without problem. Is there a possibility it has affected the connection of the digitizer to the rest of the phone? Trying to understand what aspect needs replacing.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It is possible that the lcd is damaged. But if everything is working fine that seems unlikely. The power button may have been damaged when you dropped it. Does it wake up when you plug in a charger?
完成的
You can see it attempting to wake up when I plug in a charger, but the screen then remains black. Seems to be random as to whether the screen displays successfully or not
完成的
添加一条评论
2个答案
最有帮助的答案
If it is doing the same thing when you plug in a charger the lcd is probably damaged. I would not recommend changing just the glass, as it won't help for this problem. You should be able to fix it by replacing the screen.
这个答案有帮助吗?
得分 2
添加一条评论
I have a similar issue. The screen however comes on and off randomly when I tap (quite hard) on the phone with my finger nail at several positions. It seems to be a bad connection in the display connector on the main board. Replacing the display did not solve the issue.. But if I tap very carefully on the connector, the display comes on and off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike1 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 23
总计 309
