跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1169 个问题 查看全部
dropped in water, what to do?
dropped i phone in water, had protective case on. Seems to be OK except that when I place a call and receive a call I cannot hear anything, the mute is NOT on. Have it turned off and siting in a bag of rice. thoughts????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
DONT TURN IT ON FOR A FEW DAYS. leave it in the bag of rice and power it back on in a few days. If you still have problems you might need to replace the speaker assembly. Search this forum for "water damage" or "liquid spill", you'll find dozens of threads with helpful ideas.
这个答案有帮助吗?
得分 3
添加一条评论
It is important to not turn on electronics after it has touched water. However if you want a different item than rice to tuck your electronics in you can try the Thirsty Bag.
这个答案有帮助吗?
得分 1
添加一条评论
Before you do anything insure that the device is completely powered down!
Go to the grocery store and buy the zip lock bags for the freezer that you can vacuum the air out(it works with water too). Place your iPhone or other electronic device inside and add rice too(it will capture the water as it is drawn out of the device). Now close the bag and start using the vacuum. Go back periodically and use the vacuum more. Two or three days later remove the device from the bag and gently warm the device(no more than 100 degrees). After a day of that you device should work. If not sell it to a repair shop and buy another one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Amy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 3,646
