跳转到主内容
Released in 2019, the Asus ZenBook Pro Duo UX581GV is a unique laptop with a main 15-inch OLED touchscreen along with a secondary touchscreen just above the keyboard.
How to upgrade ssd and ram?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @magedbadr
Here's a video that shows how to upgrade the SSD.
Here's a link to a supplier that shows what types of SSD are compatible with the laptop. You can use this supplier for information only to know what type and capacity SSD are suitable. There are other suppliers online that may suit you better.
Can't find out how many ram slots there are but according to the specifications the maximum may be 32GB (2 x 16GB?)
Once you have the laptop open to replace the SSD you should be able to find out. It is 2666MHz DDR4 SODIMM ram
这个答案有帮助吗?
得分 2
1条评论:
I believe the ram is soldered (sry dont know how to spell this) on. I dont know if that means you can still upgrade it, just with a lot more difficulty but most places i've seen say best stay away from that. But I am inexperienced at this so apologies if this is techie fearmongering.
thanks for the video really helped me.
完成的
添加一条评论
Well If your device is struggling, upgrading the RAM and SSD will improve performance with the help of this video you can upgrade the and if you want to give more boost to your system performance then you can install a software called Advanced system optimizer this software is a PC optimizer software which will give more boost and improve the overall speed of your system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maged Badr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 61
总计 3,018
