跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
145 个问题 查看全部
Will replacing the home button restore click function?
Hi. While trying to replace a shattered screen the home button cable was torn. Will replacement of the home button restore click functionality? I know it wont fix the Touch ID but what about click? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello!
In my experience, it requires a great deal of care to restore the click functionality in these home buttons BUT it is possible. In this iPad’s home button replacement guide, refer to steps 20 & 21 specifically. They outline how one should remove the bracket holding the home button in place and methods for reattaching the bracket to ensure clicking functionality is maintained. It may be necessary to purchase a new rubber gasket for around the home button as well, depending on damage sustained during the original repair. Make note; in step 21 the author explains that the bracket needs to be properly aligned and secured while the adhesive cures for full functionality to be restored.
OR since you’ve already were not talking about maintaining Touch ID functionality, I would likely try to return the replacement display I bought for one that has the home button pre-installed for me. I cannot emphasize how delicate this task is and how difficult it is to fully restore the click you are used to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Lin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 21
