跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
149 个问题 查看全部
Face id working only on specific face angles.
I dropped my iPhone once and the top left corner is slightly lifted. the face id was working fine, but eventually it only detects my face at particular angles after long wait time. What could be the reason? and solutions are welcomed.. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Surendar,
The Face ID system is dependent on multiple devices, particularly the dot projector and the IR camera. Since they need to work together, their alignment is critical to their proper functioning.
It seems likely to me that if part of the screen is "lifted" as you said, then it's quite possible the Face ID components are no longer correctly aimed, causing the kind of symptoms you're seeing.
I would start with correcting the problem of the lifted screen as my first approach to getting your Face ID working again. Screens have very little flex to them, so depending on how far out of alignment it is, are you sure it's the screen that's out of place rather than the frame being bent?
If you could post some pictures of the damage to your phone, perhaps we could help out with fixing your problem.
Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Surendar P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 105
