Switch Charges In Dock but Does Not Display to Monitors
Everything is working good except for no display when docked. I get a solid green light on the dock, which Nintendo says is indicating display should be being output to the Monitor. My dock/HDMI are fine, they work fine with another Switch. Charging from dock works aswell.
It has short on capacitors near M92T36 IC and P13USB but after replacing P13USB everything seems to be alright - shorts are gone.
Before replacing IC in switch's tv output settings only 480p resolution was available, now there are all options.
Usb port works on both sides too.
Any ideas how to diagnose motherboard or what need to be replaced?
did you check the filters near p13usb ?
由 daniel 完成的
Yes, there are no shorts
由 Rudey 完成的
@Rudey i dont mean for shorts i mean are they testing good
由 daniel 完成的
