跳转到主内容
Repair guides for Microsoft's Surface Laptop Go, released in October of 2020.
7 个问题 查看全部
Left my laptop overnight in cold car
Hi, I left my Microsoft surface go in the car overnight (11 hours) at about 0 degrees C (I think), and it won’t turn on… It was really cold to touch but now it’s heating up but won’t turn on. Can I fix it at home ? Or will it be broken inside ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hi,
Does it indicate that the battery is charging when the charger is connected to the laptop?
完成的
@jayeff hi thanks for your answer, I haven’t tried plugging it in since I didn’t want to break it if there’s moisture inside, but will try now
完成的
@jayeff it is charging yes
完成的
@Penny Heslop-Pemberton
Hopefully it won't take too long but allow it to fully charge and then try turning it on, with the charger still plugged in.
完成的
I would personally leave it in the house for 24 hours to gradually warm back up. It's not really the laptop, more the chemicals in the battery.
完成的
添加一条评论
1个答案
最有帮助的答案
Penny, as @jayeff has said, let it charge, then try turning it on in a little while. The important thing about electronics that has been left in a cold (but otherwise dry) environment, is to let it slowly acclimatise (as in warm back up to room temperature) before doing anything. Blasting it with heat and such, is a sure fire way to let condensation form, and cause liquid damage to the boards inside.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Penny Heslop-Pemberton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 66
总计 2,497
