跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
570 个问题 查看全部
Why won’t my console accept an OS?
I bought a PS4 Slim, and have not been able to use it. When I initially plugged it in, it was able to start, but would randomly shut off. I tried restarting, updating, initializing, and no dice. I have gone through 3 different hard drives, all three I’ve confirmed good. The problem now is that no matter how I try to reinstall the firmware, the system alleges that the data is corrupted. I have used 2 different flash drives, hard wire internet download, and have confirmed that the file I downloaded is not corrupted through initializing another system with the same file. I’ve pulled the console apart, and I see no signs of heat damage, no damage to any wiring, or the HDD port. Please help. I’m at my wit’s end, and would really like to see this thing run. Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you see visible signs of heat damage then it's going to be severe enough that the system would be completely unrecoverable. It sounds like the system may be overheating and shutting off to prevent damage, but in the process it's corrupting the filesystem due to unexpected shutdowns. Make sure all fans spin freely and actually spin up when the system powers up, ensure all air intakes and outputs are clear of dust, and also apply fresh thermal pads and paste. Afterwards, rebuild your database and see if the problem persists.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Everett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 28
