跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
148 个问题 查看全部
Unable to Boot pass logo or Restore OS
I did a reset a few months ago on this laptop and it was working at the time but the owner (my mother) didn't use it afterward because they have another computer they are using. The battery drained and it sat dead for some time. Now I've tried booting and it is stuck in a boot loop.
I can use some of the startup keys but these are the results
Command+R - does nothing
Shift+Option+Cmd+R - Starts the internet recovery, allows you to join the network, and then proceeds to download the recovery then shows "support.apple.com/mac/startup -1008F"
Option - shows the MacOS drive and allows you to choose a network. I've tried using a macOS on a USB made from another mac PC to attempt a restore. Enters BootLoop if either drive is selected.
Option-Command-P-R - Not sure if it resets the ram nothing is shown and still boot loops
D/ option - d - Same as the recovery
Can this be saved or is it a dead cause?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try creating a Linux bootable drive (https://ubuntu.com/tutorials/install-ubu...) and boot from it. If that boots, we at least have some signs of life and can maybe recover macOS. Another thing to look at this might be this Apple Support article (https://support.apple.com/en-us/HT201255 I think you've tried most of these combinations, but it wouldn't hurt to try a few more. One that might be interesting to try is "T" for target disc mode. I'm just thinking out loud (or typing) here, so there is no guarantee that this will work, but maybe you could flash an OS onto the computer via target disk mode. Maybe you could hook it up to another computer and try flashing something onto it with balenaEtcher. Again, no guarantee, but might be interesting to see what happens.
Well, I hope all this ranting of mine helps you out. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ackeem Isaac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 29
