跳转到主内容
Glow is designed with sleep in mind. Its self-dimming, warm light lulls you into better, deeper sleep.
4 个问题 查看全部
But now one of the two pogpins is broken
I live in Switzerland and have always charged my glow with a US-EU adapter. But now one of the two pogpins is broken and i need an other way to charge it. At the Moment i use a Labor Power Supply and charge it directly.
Output: 9V / 2A
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@pogopooc, Is it not feasible for you to replace the broken pin? On the previous question on this glow light we talked about sourcing the pins and referred to a video showing the process of replacing them on a different device.
Wireless Charging base failures or options? - Casper Glow Light - iFixit
I'm not sure, but I believe Digi-Key ships internationally; otherwise I'm sure you can find it elsewhere on sites like AliExpress; here's just the first example that came up.
https://www.aliexpress.us/item/325680249...
Please post a picture of your broken pin and the charging base and we'll see what we can do to help you get it working again.
这个答案有帮助吗?
得分 2
1条评论:
Thanks @Jerry i ordered the pogopins at Aliexpress and i will try to replace them. But for now the Light is charged again and also there was a Firmwareupgrade. Looking forward for the Pins. Thanks
完成的
添加一条评论
添加你的答案
Pogopooc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 23
总计 724
