跳转到主内容
加入维修社区 - 创建账户
The Dell Inspiron 1526 was a laptop released in 2008 known for the a swap-able face plates and its portability.
2 blinking lights,fan on not booting?
Turn on my 1526 fan kick on but doesn't boot the buttons on the very top of console (under screen) 2 on the right blink the left says on normally these lights would be caps look (I think) and num lock... NEVER have had an issue in the 4 years I've owned it. Please help ....!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You may consider checking the ram. If you have a pair installed, remove them, put them back in and start up the system. If nothing then...
Remove both. Add one stick and try the system. If you have the same issue, remove that one and insert the other and try it.
这个答案有帮助吗?
得分 1
2条评论:
Thank you John update: will not turn on now blue light in bottom left corner blinks makes a noise!! Did not get a chance to try the advice yet...
完成的
Thank you sir. It solved my problem on Dell insp. 6000.
完成的
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 2,711
