跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
86 个问题 查看全部
MacBook stuck in the apple logo, with fans at maximum speed
Hi, I have a 2019 macbook pro and it does not start. When you press the power button, the macbook stays in the apple logo with the fans at maximum speed. I have tried to enter DFU mode but there is no way. any idea what could happen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Hi
Did this just randomly start happening or did something like a liquid spill happen
完成的
Hi! No liquid has been spilled on the Mac and it hasn't been dropped either, so I don't really understand where the error could be.
完成的
添加一条评论
1个答案
If you spilled something on it previously, that could be a factor, and it could also be a bad battery, or a cpu/gpu issue. If you previously used it and ran it hard then it most like is a cpu/gpu issue. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Borja 1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 35
