跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1119 个问题 查看全部
Some keys are not working
I replaced the battery on my Mac, I put all things back in place, but some keys are not working now. I have gone over all the connections they seem right.
I replaced the ribbon and push the latch down on the connector, I am not getting the keys to work. The computer is working fine but I am using an external keyboard and mouse.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Which cable did you replace the keyboard or trackpad?
这个答案有帮助吗?
得分 0
2条评论:
I replaced the trackpad cable Item # IF123-130-2, with an equivalent from Amazon. I had issues with the trackpad before and when I replaced it the trackpad started to work. I guess I thought this could be related. Is there another cable that could be replaced?
完成的
@linternas - Good clue!
I’m suspecting your trackpad is having troubles while the cable connection is independent in this series between the keyboard and trackpad the signals both share the same internal USB pathway. So if one is having issues the other can as well.
So it’s time to replace the trackpad and you might want to replace the cable again if you creased it at the fold points. This cable it finicky as you can damage the foil wires within it when you fold it in half and press on the cable to hold the crease. Instead I use a tongue depressor so I don’t overdo it.
完成的
添加一条评论
添加你的答案
waxcar23 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 22
