Why is my ps4 controller not connecting to my ps4 console?
I've tried everything, including; plugging in ps4, resetting my controller ECT.,
It works perfectly fine with my ps5 and other devices.
With the PS4 off, go into safe mode by holding power until it beeps a 2nd time (about 7 seconds). When it asks you to connect your controller, try it there. If it works, then your wifi module is bad. If it doesn't work then your southbridge is bad.
For others, this advice is assuming the controller and cable are known to be working. Since OP mentions it working elsewhere, this is satisfied here.
这个答案有帮助吗?
Thanks, but already fixed it.
Hi @Rec rooms fan! Ytp
How about updating your question with how you fixed it if the above answer wasn't the fix, so as to help others who may have the same problem.
Click on Options > Edit in your question
Moderator
I connected my controller to my phone and now will not connect back to play station please help
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 2,865
