跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 游戏主机的一款更实惠、纯掌机版本,具有集成式 Joy-Con 控制器和稍小的屏幕。于 2019 年 9 月 20 日发布。
Can I get a replacement piece I broke off the small piece
Like in step 27 of replacing the joystick cable on the lite
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
A picture would help. Put one up so we can see the issue you have.
完成的
[image|2842293]
Sorry I’m new to this. Can you see the picture
完成的
@erica341 no sorry. If you click.edit on your original post there should be some icons appear. Click on the picture one then find your pic and upload it.
完成的
@erica341, are you saying you broke off the little black lever from the joystick cable connector that's mounted on the motherboard? Is that what you're referring to? "Piece" by itself doesn't tell us enough for us to be able to help.
完成的
添加一条评论
1个答案
最有帮助的答案
@erica341 here is a website that you can lookup for technicians in your area. https://repairlegion.com/repair
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Erica 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 381
