跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Water damaged PS4 controller
My controller ended up in the water for about 5 second, I took it out, dismantled straight away and dried, cleaned with isopropyl, put everything together and it works perfectly fine but ONLY when on charge, when i disconnect from charging the light goes off straight away. I have another controller that I took apart and swap the battery and back panel and still the same issue, when I put battery and back panel from flooded controller to the working one everything works, no issues. Tried resting controller with pressing the reset button for 10 second but nothing changed, is it beyond repair? what should I do next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey, Dawid
There is likely an issue with some cables within the controller, so I don't know how to proceed with repairs. However, I would suggest trying different cables/wiring from the battery.
这个答案有帮助吗?
得分 0
1条评论:
there isn't really that much cables to try
完成的
添加一条评论
添加你的答案
Dawid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 117
