跳转到主内容
The 2016 Kia Optima went on-sale towards the end of 2015. It shares a platform with the 2015 Hyundai Sonata, and offers a new design, with new features and enhancements.
5 个问题 查看全部
How do you repair a gas gauge
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi sharon2202,
There are three parts here to consider, the dial in the dash, the wiring between and the sender in the gas tank.
The most common failure is the sender, and the cure is generally to replace it. That means accessing the fuel pump retainer, which can either be in the trunk or under the rear seat, opening it up and removing the fuel pump, then replacing the sender. Here's a short page from Kia showing how to replace the fuel pump on an Optima.
Kia Optima: Removal - Fuel Pump. Repair procedures - Fuel Delivery System - Engine Control/Fuel System - Kia Optima TF 2011-2023 Service Manual
We would need to know what year your Kia is to give you an more specific information, including where to get the part for it; you can get the sender separately from the fuel pump, or buy a whole new fuel pump with the sender already installed. Obviously it'll be cheaper to just get the sender and replace it on the pump yourself, but you may have to figure out how to do that.
Less common issues would be a break in the wires connecting the sender to the dash gauge, which can be difficult to diagnose, and finally the gauge itself, which would involve removing the instrument panel and disassembling it to get to the gauge, but those failures are pretty rare; I'd definitely start with the sending unit in the gas tank.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sharon2202 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 69
