跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
Why when I start my pc it doesn't open and there is an underscore in t
请参阅图像内容:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Could you clarify and did you try pressing F1 and doing the setup?
完成的
添加一条评论
1个答案
最有帮助的答案
Jhon, as @verhulstak already mentioned, the computer needs the time and date set in the CMOS memory, and if I had to guess I'd say the CMOS checksum is probably wrong due to it being erased (or never set). Do as it asks and press F1, then set the correct time and date and make sure to do a save afterwards.
If it continues to ask for that information after you've set it, then it's likely the CMOS battery is dead or missing and will need to be replaced.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jhon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 116
