跳转到主内容
加入维修社区 - 创建账户
• 输入接口:iPod™ 底座接口 / 3.5mm 立体声插孔 • 扬声器:2x Ridge TM 高/中音单元和 2x Atlas TM 低音单元 • 功放功率:2x15 瓦高/中音,2x30 瓦低音 • 频率响应:40Hz – 20kHz • 输入阻抗:>10kOhm • 电源:8x D 型电池/充电电池,电源适配器 • 尺寸(长x宽x高):500mm x 230mm x 240mm
How to replace one of the speakers on my HK Go + Play Model IT782Y
How to replace one of the speakers on my HK Go + Play Model IT782Y?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Here's a teardown video for a HK Go Play speaker. It doesn't specify the exact model number of the speaker so hopefully it will still be of some help.
There is usually information printed on the back of the speaker driver itself that may help you to find a replacement speaker, perhaps more than just its impedance value in Ohms. There is some information printed on the speaker coil that can be seen at 3:06 minutes into the video but unfortunately it is too small to be able to be read clearly
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alan Boswell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 43
总计 1,857
