跳转到主内容
加入维修社区 - 创建账户
Super Nintendo Entertainment System (SNES),或简称为 Super Nintendo,是任天堂于 1990 年发布的一款 16 位游戏主机。Super Nintendo 是当时最畅销的产品之一,至今仍拥有庞大的粉丝群。
Why is Super Mario World missing assets/wrong colors?
The game boots fine, but colors are switched and Mario is a little jumble of demon text. The game functions perfectly fine, just an eyesore. I've tried cleaning the contacts, processors, and console, but nothing has changed. I've even tried re-flowing the cartridge. Any ideas on how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Other games work perfectly fine by the way.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi
Iv seen things like this happen on gameboy cartridges and it id usually due to ether damaged traces on the PCB, Loose pins on a Chip or corrosion
The best thing you can do is open the cartridge
Here’s a disassembly guide for that:-)
https://m.youtube.com/watch?v=raw6ve2fcr...
Once opened make sure that all chip connections are good ,make sure there’s no corrosion and the PCB looks to be in good condition
If any corrosion is found ,isopropyl alcohol is a good cleaner
If any loose pins are found you can resolder them back to the PCB
And if any traces are damaged a jumper wire will need soldered to close the gap:-)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Daniel Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 377
