跳转到主内容
加入维修社区 - 创建账户
Uses a smaller heatsink and a user-screwable stand.
HDMI behind the ps5 is damaged
HDMI doesn’t work behind the ps5 anymore
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
添加一条评论
3个答案
已选择的解决方案
Very common problem for the PS5, Its a terrible solder job from the factory. I have repaired a few.
HDMI needs to be resoldered to the board or replaced if damaged..
这个答案有帮助吗?
得分 11
2条评论:
Was in a situation where I had to move out quick and was mad and pulled the cords fast and the hdmi port is crooked
完成的
How much is it gonna be
完成的
添加一条评论
I have this same problem too can someone direct me on how i can fix it?
这个答案有帮助吗?
得分 0
6条评论:
@davidmanteaw let's see if our game console Guru @dan0 can assist you with that.
完成的
Hi!
Did you tried a new cable? Does the port look damaged? Can you share some pictures with us regarding the port? Thanks!
完成的
I checked the ports and it doesn't look damaged. Regarding the pictures i do not know how to share it here because im new to the site
完成的
@davidmanteaw unless you're good with liquid metal and soldering id find a reputable repair shop and have them do it. For some reason sony decided to use liquid metal as apposed to thermal paste. If you're not careful it can get everywhere and possibly kill the board.
完成的
Alright @Ted i think ill do that. I wanted to fix it myself to see how id go about it. But because im highly inexperienced i think your suggestion is much better
完成的
显示更多的1条评论
添加一条评论
How much would it cost to fix my HDMI port. All pins in the port looks okay but the it wont show on the tv screen for some reason? So how much to fix it in a repair shop?
这个答案有帮助吗?
得分 0
1条评论:
Depends on where you live… hard to say. And every repair shop have there own prices.
完成的
添加一条评论
添加你的答案
sfwjojo382 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 68
过去 30 天: 310
总计 7,849
