跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
I am locked out by a passcode I so not use
I was trying to input my Apple ID; got it wrong again and again and before I knew it I was locked out of my phone entirely. It is demanding a 6 digit passcode. I do not use that so how do I get around this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Have you bought the phone second hand or have you had it from new?
完成的
添加一条评论
2个答案
This apple guide should be able to able to help you out! Are you erasing your data on your iPhone 11 if I may ask? You'll have to put your device in recovery mode if you get locked out too many times by your device passcode or if you forgot.
这个答案有帮助吗?
得分 0
添加一条评论
start with this - https://support.apple.com/en-us/HT204306
if that doesn't work and if you absolutely cannot remember your 6-digit passcode, there's the nuclear option. download and install 3uTools on your PC, boot up the phone and connect it to your PC, use the Flash feature and do an anti-recovery flash.
WARNING - BE AWARE!!!!!!!!
  • this will update you to the latest IOS and return the phone to OOTB condition and you will have to set up your phone again
  • all your data will be lost, i hope you have a recent backup.
  • if you do have an iCloud account connected to the phone it will still be there, hopefully you can remember that password - however, if you can't there are methods via appleid.apple.com or www.icloud.com to recover/reset that password, provided you have access to that account's email and the phone number for two-factor authentication is still good.
Hope this helps. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maureen Bellows 将永远感激不已
浏览统计数据:
过去 24 小时: 39
过去 7 天: 181
过去 30 天: 757
总计 883
