跳转到主内容
Repair guides and support for smartphones manufactured by Doogee.
Trying to get the screen out to replace charging port
My Doogee S59 Pro's charging port was broken by a cheap type C charger, and it has glue all around the screen, which I need to remove to access the Charging board. Does anyone know of something that will dissolve the glue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Heat! Just apply heat (100C) around the screen for 8 to 10 minutes, then pry on it (gently). I've been trying to get it out for months then saw this video! https://youtu.be/LM5Qae_A5oU
这个答案有帮助吗?
得分 1
1条评论:
hi there, i have the same problem, did you finally replace the charging port ?
完成的
添加一条评论
添加你的答案
Anchevauls Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 411
