跳转到主内容
Optical drive from 2009 MacBook incompatible in Late 2011 MacBook Pro?
Hi all, i swapped the (working) disc drive from a Late 2009 MacBook into a my Late 2011 MacBook Pro that had a broken drive and all it does is take the disc then spit it back out again, is the drive just incompatible? or is there something i could do?
I haven't tested the original drive from the 2011 in another Mac, but could it be that the logic board has an issue with disc drives?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hi
Have you considered that the issue could be caused by a bad optical drive cable?
As you said it could also be a logicboard issue but it might be worth trying a different cable
I don’t think it would be a compatibility issue as optical disk drives are like hard drives ,they all use SATA so they are all basically interchangeable
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
Apple changed vendors and the drives firmware a few times as such some won’t work across different series.
Compare what you have across these two lists.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 63
