跳转到主内容
三星的第十代旗舰“平板手机”,带有S-Pen和5G功能。发布于2019年8月。
18 个问题 查看全部
Can't detected my S-Pen after my Phone has dropped in water.
I'm checking my S-Pen can work properly ,test by another device.
How can I Replace some part that my phone can be use S-Pen again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @nineonescafe ,
Even though the phone has a IP68 waterproof rating this doesn't mean that it is still completely waterproof. The phone may have been damaged when it entered the water and some may have got in
Check if the liquid damage indicators have changed colour.
If they have then the impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy Note10+ 5G guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 1
1条评论:
Thank's for your kindly @jayeff ,I'll try to fix its. ^_^
完成的
添加一条评论
添加你的答案
P.Rashann 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 31
总计 662
