跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
Overheating -- Fan not spinning
I have an 80gb CECHE model PS3. The fan isn't spinning up, and it's overheating in 15 minutes or so from being turned on. I know the fan itself works because it will spin up for the "fan test."
Is this a sign that my solder is already cracked, or will changing the thermal paste fix the problem? Or is it something else entirely?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Anyone know anything about this???
完成的
im confused...the fan is or is not spinning while it is on(not during fan test) also have you taken this unit apart at any time?
完成的
The fan is not spinning when the unit is on. I took it apart to clean out the dust, but didn't do much more than take the case off.
Maybe the thermal paste is so bad that the unit overheats before the heat sensor knows to turn the fan on?
完成的
Replaced the thermal paste. System behaving the same as before. Dang.
完成的
Performed YLoD repair. When I turned the system on afterwards, the fan came up. The fan cycled to max speed within 10 minutes, and then I got the "the system is hot" message and an auto-shutdown. Now what?
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
Cleaning out the dust doesn't always solve the problem. Bearings in fans go out all the time or if you live in a home with cigarette smoke the nicotine and tar can jam it up.
You can pick up a new fan for just a few bucks and replace it.
这个答案有帮助吗?
得分 1
1条评论:
Right, but I know the fan itself isn't bad because it comes up and runs like a jet engine for the fan test. So it must be an issue related to the heat sensor somehow...
完成的
添加一条评论
My ps3 fan is not spinning when it is turned on is it the fan its self or something else
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cowdisciple 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 5,262
