跳转到主内容
加入维修社区 - 创建账户
A robotic vacuum cleaner is a device that uses automated technology to clean floors. It uses sensors and algorithms to navigate around obstacles and furniture, suctioning up dirt and debris.
My robot isn't cleaning any of dust and garbage but it worked at first
my vacuum cleaner robot isn't cleaning the dust but it was working well the first time I use it. Indeed, I charge it, but it takes a long time and didn't reach the full charge level. what's the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
In order to give a more specific answer I'd need a model number but, generally, here's what you should do:
  1. Clean the sensors on the sides, front, bottom, etc.
  2. Check the brushes to see if they're in good order. If not, or if you haven't replaced them in a year or more, you should order them online either from the manufacturer or through a third party seller via Amazon or eBay.
    1. Check the roller brush as well for the same situation
  3. Clean out the container that collects the dirt/dust with soap and water, and let it air dry
    1. While you're at it clean the filter out using this same method. If the filter is really bad you should replace the filter.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rayan Kiwan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 89
