跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
MacBook Pro Mid 2012 keys "qwertyuio" not working at all. Help!
Hello,
My keyboard keys on my Macbook Pro Mid2012 "qwertyuio" have stopped working. I went away for 2 months and upon returning turned on my computer to see if it was working. It didn't respond so I plugged in the charger. When the computer officially turned on the following keys stopped working "qwertyuio".
I've reset my computer PRAM and also factory set and that hasn't solved it.
Would appreciate any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you have a liquid spill at some point into the keyboard and/or trackpad?
这个答案有帮助吗?
得分 0
3条评论:
No liquid spills
完成的
@gabrielleqsey - at this point you need to take the bottom cover off as I’m suspecting the battery as swelled up pressing onto the keyboard and it’s cable. Here’s the needed part MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery if you compare yours to the image here I think you’ll find one or more cells have puffed up. Here’s the guide you’ll need to follow.
FYI - if this is the original battery it’s not unexpected as Barrie’s only have a useful life of five years which clearly has long expired here.
完成的
@danj Yeah it's the original battery. I will get order this one and see if it solves the problem. Thank you!
完成的
添加一条评论
添加你的答案
Gabrielle Q-Sey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 49
