跳转到主内容
iPhone 13 mini 于 2021 年 9 月 24 日发布,它是 Apple iPhone 13 的缩小版,也是第二款的迷你 iPhone。 iPhone 13 mini 具有 5.4 英寸 OLED屏幕、A15 仿生处理器和后置双摄像头。
After Housing Swap Apple Pay Not Working
Hello
I did a Housing swap with a wireless charging pad installed and other small parts preinstalled. Now the customer's Apple pay is not working I think it might have to do with the wireless charging pad possibly part is serialized. Has anyone else come across this issue yet? Do you know what part is connected to apple pay?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Define “not working”.
Is it just not sensing NFC, or there is an error when trying to activate a new card or paying with an existing card? Does Apple Pay in app or webpage work?
NFC is at the top end of the phone, check if you have messed up any of the top antennas and screw posts.
这个答案有帮助吗?
得分 4
2条评论:
I don't have the phone but those top antennas were replaced because small parts were pre-installed.
完成的
@consistent Probably installed wrong.
完成的
添加一条评论
The nfc sensor is in the charging coil so you might have to swap that over for it to work again. When you say ‘small parts’ what was included?
这个答案有帮助吗?
得分 0
1条评论:
NFC is NOT in the charging coil.
完成的
添加一条评论
NFC antenna is on the top by rear camera.
When you say ApplePay doesn't work, it doesn't work at all or does Wallet show up when your double click side button? If it shows up, then it's antenna issue. make sure it's connected properly and replaced NFC antenna from original housing.
这个答案有帮助吗?
得分 0
添加一条评论
If, by "not working" you mean that the customer gets the message "Unable to activate Face ID/Touch ID on this iPhone," then it is because the Face ID and Touch ID components are serialized to the logic board. They cannot be replaced. Apple cites security concerns for this, but I think it is just that Apple wants you to have one more reason to buy the latest iPhone instead of repairing your old one. #rightrorepair
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark D Schlossman 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 32
总计 1,111
