跳转到主内容
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
Why is my Mac Mini turning off automatically?
For some reason, my Mac Mini G4 (1.42) keeps turning off automatically. I've tried to use different power supplies (85w and 110w), applying new thermal paste, booting into a 10.5 install disk, and none of that worked. It would turn on very briefly (30 seconds to a minute or so), then turn off. If it matters, the hard drive was dead inside the computer. However, I've tried turning on the computer w/o a hard drive and still got the same result. Please help and thank you for your time.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
One of the problems with these older systems is failing capacitors.
Between the electrolytic capacitor plague and Tantalum capacitor failure from age (shorted). You will need to check the logic board carefully inspecting and testing each one in the power rail logic.
Sadly, we don’t have schematics or board views to reference on any mini. So his makes the task even harder.
That only leaves swapping out the logic board with a good one.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the response, I'll look into replacing the logic board or the caps.
完成的
添加一条评论
添加你的答案
ducc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 254
