跳转到主内容
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 100
29条评论
Has the phone been dropped or damaged at all?
完成的
I did factory reset but still not working
完成的
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
完成的
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
完成的
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
完成的
显示更多的24条评论
添加一条评论
29个答案
最有帮助的答案
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
  1. Restart your phone: Sometimes, a simple restart can fix minor software issues.
  2. Check if the WiFi and Bluetooth toggle switches are on: Go to Settings > Connections and make sure that the toggle switches for WiFi and Bluetooth are turned on.
  3. Check if the WiFi and Bluetooth chips are enabled: Go to Settings > About phone > Hardware information and make sure that the WiFi and Bluetooth chips are listed as enabled.
  4. Check if there are any software updates available: Go to Settings > Software update and install any available updates.
  5. Check if there are any issues with the router: If you're trying to connect to WiFi and it's not working, try connecting to a different WiFi network to see if the issue is with the router.
  6. Reset the network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all the WiFi and Bluetooth connections on your phone.
  7. Factory reset your phone: If none of the above solutions work, you may have to perform a factory reset of your phone. Keep in mind that this will erase all the data on your phone, so be sure to back up your important files before doing this. To factory reset your phone, go to Settings > General management > Reset > Factory data reset.
这个答案有帮助吗?
得分 28
37条评论:
I did factory reset but it still doesnt wrk
完成的
Hi I did all but didn't work
完成的
After the last Samsung update my wifi and Bluetooth isn't working as well
完成的
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
完成的
Same here to me
完成的
显示更多的32条评论
添加一条评论
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
这个答案有帮助吗?
得分 10
10条评论:
how to replace the esee or heat it up?
完成的
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
完成的
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
完成的
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
完成的
Even if I refractory doesn't work
完成的
显示更多的5条评论
添加一条评论
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
这个答案有帮助吗?
得分 7
2条评论:
I did perform factory reset but still the same. Help me out pls
完成的
How can we replace Or heat it where it is inside the phone?
完成的
添加一条评论
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
这个答案有帮助吗?
得分 4
4条评论:
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
完成的
No hardware issue this is new update issue.
完成的
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
完成的
My Samsung a10s have the same problem
完成的
添加一条评论
turn on bluetooth to connect to nearby devices
这个答案有帮助吗?
得分 4
1条评论:
Still my phone doesn't want to open
完成的
添加一条评论
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
这个答案有帮助吗?
得分 3
1条评论:
Thank you, Anthony, but this is not a solution to problem.
完成的
添加一条评论
Why is my wife and Bluetooth working
这个答案有帮助吗?
得分 3
添加一条评论
Try to format your phone
这个答案有帮助吗?
得分 3
添加一条评论
Heat ic 300 ⁰c but how can i show the ic
这个答案有帮助吗?
得分 2
添加一条评论
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
这个答案有帮助吗?
得分 2
3条评论:
You can't update phone without WiFi
完成的
Even if I restart don't enable and not op6
完成的
I did restart but still is not working
完成的
添加一条评论
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
这个答案有帮助吗?
得分 2
添加一条评论
Wifi end blootot hospot
这个答案有帮助吗?
得分 2
添加一条评论
WiFi not opening
这个答案有帮助吗?
得分 2
1条评论:
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
完成的
添加一条评论
My wife and bluetooth are not working on my phone my phone is Samsung A10s
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
Bluetooth 11
这个答案有帮助吗?
得分 1
1条评论:
WiFi and Bluetooth connection is not working
完成的
添加一条评论
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
这个答案有帮助吗?
得分 0
添加一条评论
My wifi and bloototh not working
这个答案有帮助吗?
得分 0
添加一条评论
My wifi and Bluetooth malfunctioning since last 2 months
这个答案有帮助吗?
得分 0
添加一条评论
Why my wife and bluetooth not working on network
这个答案有帮助吗?
得分 0
5条评论:
完成的
My bluetooth and wife are not working my phone is Samsung A10s
完成的
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
完成的
My wifi and bluetooth not working
完成的
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
这个答案有帮助吗?
得分 0
添加一条评论
Wifi Bluetooth not working why problem factory already but not solve
这个答案有帮助吗?
得分 0
添加一条评论
Why Bluetooth say disconnected
这个答案有帮助吗?
得分 0
1条评论:
Answer me plz
完成的
添加一条评论
I do no but it's is in software complaint
这个答案有帮助吗?
得分 0
添加一条评论
How i can fixit
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
I don't no but I want to learn
这个答案有帮助吗?
得分 0
添加一条评论
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yidnekachew 将永远感激不已
浏览统计数据:
过去 24 小时: 26
过去 7 天: 146
过去 30 天: 699
总计 77,279
