跳转到主内容
Repair guides and support information for RCA-brand tablets.
RCA 11 Delta Pro keeps shutting down completely
I have an RCA 11 Delta Pro. It keeps completely shutting down. It doesn't matter if it plugged in, battery 100%, docked to keyboard, or anything. It will continuously shut right down. I've tried factory reset. That worked a couple times, but now it just won't stay on. It's now to the point where I press the power button, the load screen comes on, and the lock screen will pop on breifly and then shutdown (have to press and hold power to turn on again). If anyone can help, would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Sounds like your battery is really worn out.
这个答案有帮助吗?
得分 0
3条评论:
try clearing cache
完成的
@ipodgirlboss I've factory reset the tablet. Multiple times. It wouldn't be the battery either, as it still happens at 100% charge and plugged in.
完成的
what i mean is that the battery is too weak to keep the tablet on, even if it charges to 100% it doesn't have enough capacity anymore.
完成的
添加一条评论
添加你的答案
Christopher Kosc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 333
