跳转到主内容
The Samsung Blackjack is an AT&T smart phone with 3G capabilities that runs on the Windows Mobile 5.0 OS.
What do I need to buy if it won't turn on?
My old BlackJack won't turn on, I'm willing to find parts to replace but I'm not sure what I would need to get.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi,
Does it indicate that it is charging when you connect a compatible charger to it or connect it to a computer?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi Cameryn,
First off, what's the history of this device? I'm going on the assumption that it's been sitting in a box for a few years and now you've pulled it out, dusted it off and are trying to get it to come to life. Is that close, or is there more to the story? Let us know, as that can affect how we go about figuring out how to bring it up.
So with that as the starting point, the first place to start is with the battery. All batteries have limited lifetimes and long periods of sitting discharged can kill them quite effectively. So a new battery would be my first purchase. Next, you'll want to try and verify the charger. That's going to be a bit of a pain, since it uses a 20-pin proprietary pinout on the charging port, so it might not be easy to figure out if it's working or not. You might try and locate a pinout for that connector and see if you can measure the voltage on the power and ground pins if you can figure out which ones they are. The charger itself should state what the output voltage is, so at least you'll know what you're looking for.
I'd say start there and let us know what you find then we can figure out what the next steps are once we're reasonably confident it's got power.
这个答案有帮助吗?
得分 1
添加一条评论
Check the Battery, most likely, this is exactly the problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cameryn Cazan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 261
