跳转到主内容
MacBook Pro 2011 Won't boot from a internal SSD
Hi
My system will not boot if I put a Bootable SSD internal, the same SSD will boot from a USB enclosure, I have change the HHD Cable 2011 with one from Amazon and still no luck.
The system will boot fine from a 1.5t HHD internal or USB I can even boot from a SD card.
if I hold down the option key with the SSD internally the system sees it and the recovery drive but when I select it I just get the flashing folder..
so I have read that I should order the 2012 cable as it is much better then the 2011 cable.
any help wold be great
Terry
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would still replace the HD cable as SSDs run harder so a weak cable often shows up under it Vs a HDD.
Did you select it as your boot drive?
这个答案有帮助吗?
得分 1
2条评论:
Yes I replaced the cable from Amazon and still no luck, but the same SSD will boot fine from a USB enclosure
完成的
@Terry Genereaux - Did you check the startup drive within prefs? Also did you install the same OS version your HDD has?
完成的
添加一条评论
添加你的答案
Terry Genereaux 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 131
