跳转到主内容
Repair information for LG ovens, ranges, and stoves.
Broiler doesn’t lite up
Lg gas range, LG 4513BD, 5 yrs old and the broiler has never worked. No heat!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Did you mean model LSG 4513BD?
If so here's the service manual that may help.
Don't know too much about gas ovens but perform the SVC test mode in Section 7-1 and check if relay RY12 operates. This relay appears to be associated with the broil function.
There's also the wiring diagram in the manual which may help if you need to check the broil function wiring circuit - see Section 6-1
Hopefully this is of some help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Derrick Lawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 78
