跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
What can cause the screen to become white after starting normally?
On my MacBook Pro Retina 15'' (Mid 2015 - A1398), a "service" store replaced the battery and since then, the screen stopped working normally. It starts almost totally white (however brightness control works). But what is really weird is that if I leave it turned off for 1 or 2 weeks, then it will start normally, image is perfect, and after 10 or 15 seconds, it will turn to white again. Then shutdown/restart won't fix it.
I already tried to open it, disassemble the screen from the computer, disconnect the cable and clean the connectors with isopropyl alcohol, but this did not work. I looked for people having similar issues and it seems to narrow down to the LCD screen or the LVSD cable. Examples:
My display is slowly fading to white. Why?
Why does my screen turn white?
I ordered 2 new cables and am waiting for them to arrive to try to replace it. I am not replacing the screen, but it seems strange to me that after some time without being turned on the screen is perfect again for 10 - 15 seconds. The computer works on an external screen.
Is there a way to be sure it is the cable and not the screen before replacing it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would have tried an external display to help narrow down the issue. If the external works without fail then we know the issue is within the display assembly. If the external Also reacted going white then the issue is within the logic board (GPU)
As far as the cable there is only one that is needed if that where the issue MacBook Pro retina 2012-2015 display cable
But your symptoms and testing tells me your displays T-CON board within the lid is the issue. Which means you need a new display assembly.
The two links you posted are for very different systems! These both use LVDS signaling whereas the retina series uses eDP or iDP signaling which reacts differently.
Just like how the older analog over the air TV signaling is different than the digital.
MacBook Pro Retina (2012-2015) Display LVDS Cable图片
产品
$14.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
evil mandarine 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 32
