跳转到主内容
加入维修社区 - 创建账户
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
iPhone XR bootloop after screen replacement
Hello guys so yesterday 31 Dezember I replaced the xr Display and then the iPhone started only when plugged in had a bootloop iTunes and 3utools didn’t work
I also don’t own the original display because ist got replaced before by someone else
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi
When you replaced the screen did you unplug the battery?
If you did it might be worth checking how well the connector is seated as a poorly seated connector can cause a bootloop
Also if the battery wasn’t unplugged it could have caused a board level issue which would need further investigation
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hypejakob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 108
