跳转到主内容
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 个问题 查看全部
When I turn on my car it sounds like the engine is hitting something
When i turn on my car the engine sounds like it hitting something but when i go check its nothing after a few minutes it stops it had good oil amd everything is good all the fluids
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi steve,
I did some checking and apparently your car most likely has a timing chain rather than a belt. I used to work at a Datsun dealership where all the cars had timing chains and the first time I heard a loose timing chain I knew exactly what it was; the sound was unmistakable. Over time the chains stretch until the combination of that and the tensioner getting worn down allows enough flex in the chain that it rattles.
You won't be able to tell for sure on your car unless you take off the timing cover and examine the chain. It should be taut with no slack in it at all; if there is, that's most likely the source of the noise you're hearing.
To get any more detail on your problem, it would help a lot if you would add information about the year and engine size of your Grand Am.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
steve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 11
总计 35
