跳转到主内容
The JBL Pulse 4 is a portable Bluetooth speaker that combines impressive sound quality with a mesmerizing 360-degree LED light show.
8 个问题 查看全部
Is my JBL Pulse 4 cannot be fixed?
Good Day Guys! My borrowed JBL PULSE 4 works fine, adding the use of JBL Portable app to customize lightings etc. But I had a problem after the software update of the JBL Pulse 4 using the app, after the update was completed, the speaker won't turn on anymore, neither is charging, it doesn't respond to anything, completely nothing works. The app JBL Portable, broke my borrowed speaker because of the software update it showed on the app. Please help, is there any ways? 😭😭😭
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Have you tried a hard reset? I know you said it won't turn on, go through the process and see what happens.
这个答案有帮助吗?
得分 0
2条评论:
What's the hard reset you're talking about? I've tried long pressing the power button for 30 secs or more, doesn't work. Tried pressing both play button and volume up button, nothing happened. And any other combinations, I guess. What else?
完成的
Have you tried both power and volume up together for 30 seconds? Then try and turn it on? My bose wouldn't turn on so I plugged the charger in then when it made a sound I turned it on and unplugged the charger. Been fine ever since. I take it was charging OK before the issue?
完成的
添加一条评论
添加你的答案
April Chan R. Sabio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 527
