跳转到主内容
加入维修社区 - 创建账户
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
PS4 won't accept any disc's even after new drive installed
I bought a new optics drive from ifixit and after taking it completely apart and replacing the drive it still won't accept any disc's.
My old disc drive was failing and I had to tap the top of the ps4 while inserting cds, so I think it was the drive failing. But its still happening after the repair. I can manually insert the disc but it won't even recognize when I'm attempting to put a disc in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Tell me if I'm wrong, but what I'm reading is that you go to stick the disc in and the console continues to sit there like you're not. If so, you likely have a blown fuse ON THE MOTHERBOARD. All swapping the drive would do is put presumably clean gears in place of the ones that have debris in them that strained the intake motor in the first place. Generally speaking.
Here's where you find Slim BD fuses on the motherboard.
Here is where you can source replacement 0402 BD fuses.
这个答案有帮助吗?
得分 1
1条评论:
Thank you Dan for the response.
Yes when ever I try to put a disc in it does not attempt to automatically pull the disc in.
I will look into the potential fuse issue and let you know if it is the issue!
完成的
添加一条评论
添加你的答案
Joshua 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 114
