跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
Why is my mac not able to find the SSD?
SSD is not getting detected on macbook pro 1707. Checked for power supply in all NANDs.
The diskutil is also not showing the hardware nand attached to the system
The NAND power distributor is getting over heated but the power supply is proper. I have checked all the NANDs in the attached image for power supply.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Ouch! Sadly your systems logic board has a problem! It could be the flash chips them selfs failed a common issue with smaller drive setups which have too much stuff! You really need to leave 1/3 of the drive free! The larger drives need about 1/4. Otherwise the drive is over taxed.
It’s also possible you have corrosion damage due to a liquid spill.
Best to find someone local who have the needed Mac & micro soldering skills
这个答案有帮助吗?
得分 1
2条评论:
@danj, thanks for the reply. I believe I have fair amount of soldering skills for the job. I have checked for liquid corrosion etc. and they don’t seem to be the cause. I have also checked the voltage supply on all the 4 drives and that seems to be proper.
Need some direction on how to diagnose the root cause.
完成的
@Abhishek Rastogi - How many times can you bend a coat hanger before it snaps?
Flash chips are no different! You can only write to the given cell so many times. To extend the life of the Flash wear leveling is done and there are also spare cells held in reserve to back fill.
Now how full the drive is impacts the drives ability to wear level the smaller the drive the less it can be written to.
That’s the root issue if you don’t find any corrosion or other failure.
So… you may need a new logic board as replacing the Flash chips doesn’t make economic sense and given the density of the logic board you’ll likely damage it in the process of replacing the chips.
完成的
添加一条评论
添加你的答案
Abhishek Rastogi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 153
